Lowrance GPS replacement
Over the last weekend our Lowrance GPS/Chartploter fitted as original equipment on our 2008 Rinker 280ec went faulty and it appears to be the LGC-3000 GPS module that has failed. I've contacted Lowrance support and they advise that there is no longer a direct replacement available for this module and they do suggest an option using an NMEA0183 antenna. However, as the whole set-up is now over 10 years old and the technology is even older, perhaps this is the time to replace the entire set-up. Obviously something that was as direct a replacement as is possible -- flush mount into the helm in the same location -- would be good. Sonar is not that important to us, unless it used a through hull transducer, as she has only just gone back in the water after extensive work and I don't really want to lift out again so soon afterwards.
Has anybody replaced theirs? Any suggestions or recommendations would be much appreciated.
Best Answer
NickWight Member Posts: 30 ✭✭
Thanks for the suggestions and I'm now looking into a "direct" Lowrance replacement! Nick.
Replaced it with Lowrance Elite5M HD. Internal antenna unit. Far more user friendly. Only a bit of minor dremel work on the dash to fit.
Actually surprised that you have been able to keep your original unit functional that long.
