Installation of Jabsco Twist n Lock
Willhound
Member Posts: 4,236 ✭✭✭✭✭
A P.O. had installed a goofy electric head pump conversion that I never liked. Noisy and drew way too many amps. It quit on the weekend so I decided to just go back to a manual Twist n Lock pump. Instructions aren't great. Can anyone confirm that the base gasket/valve flapper goes flat side up as in first pic? I assume it does because otherwise the raised bump on the other side hits the piston. Does it matter if the flap is left or right? I'm thinking open side to the bowl?
YouTube · Jabsco Rule Marine
One question I do have though, is that I've heard from others that with the Twist N Lock pump you should leave the toggle and/or handle in a certain position to ensure no damage when pumping out. But I don't know what that position is and can't find it anywhere.
Anybody else heard this?
Toggle to the right, twist and lock the handle down when not in use!
