rinker 260 2009 water in engine..
griffin0165griffin0165 Member Posts: 5
Hi guys
I Had a new Volvo engine fitted last year Oct 2017 due to old engine block went pourus that was the Volvo 260 GXI
Approx 4 weeeks ago I went out to sea with the the family 2 Adults 2 children drove around for 30 mins then decided to stop for something to eat.When I went to start the boat she wouldn’t turn over.It was just making a clicking noise.
Any fast forward engineer has found water in cylinders 2-3 😬😬
Has anyone out there had this type of problem with this model of boat.
Please can someone shine some light on this issue Please..
    Couple things come to mind.
    Blown / defective / improperly installed head gasket.
    Exhaust flappers are shot allowing water to backflow into the engine.
  • griffin0165griffin0165 Member Posts: 5
    Hi
    thanks for your comments the boat engine is coming out on Monday for diagnosis.
    They seem to think it could be my fault 😬
    ive only used it 3 times with 20 hrs on clock
    The boat survey fella said I may have stopped to suddenly and water has gone up into risers.
    Obviously they will try and blame me for this ?
    Any ammunition out there
  • aero3113aero3113 Member Posts: 9,622 ✭✭✭✭✭
    Your exhaust shutters should’ve prevented that if that was the case. With only 20 hours the shutters should be working properly.
    Thank you for putting my mind at rest....
    I will keep you informed
    Salt water yes manifolds where replaced and also the boat at the time was sitting level...
    And I was not going backwards?
    Hi All
    the guys who fitted the engine are saying that the risers need raising which is a Manufacture fault?? that’s why water has entered engine,so they are not taking responsibility for their installation of New engine!!
    Has anyone out there heard of this please??
