how can stop my motors from getting wet in rinker 342
CRILLERCRILLER Member Posts: 14 ✭✭
edited July 2018 in Rinker Support Q&A
when it rains hard water over flows into my motor compartment and motors won't start. seems like to much water comes in motor compartment in stead of going out scuppers in rear. anybody have this problem?
    Are you sure the gutter all around the engine compartment is clear so that water can flow out? If there is crap in the gutter around the engine hatch it will overflow in to the engine room.
  • CRILLERCRILLER Member Posts: 14 ✭✭
    yes it's completely clear and clean
    get in there with a light and have someone outside with a hose
    Do you leave your boat uncovered during heavy rains often?  That alone can't be good in the long term.
    no i keep canvas on it.
    Has the cover been water proofed lately?  Mine needed another application to stop water from soaking through.
    The soaking through led to water getting into my engine room as well. What I have found on my boat is the sound dampening panel is too large and sits in the gutters when engine hatch is closed.  When it rains, the panel gets soaked and drains into my engine room.  When I lift the engine hatch when it, it POURS all over my engine and batteries(recently put covers over battery).  I am trying to fix this problem.  Just a thought, not sure if this is your problem.
    I miss my covered slip...
    Patrick
    06 Rinker 270
    i took the sound dampening off the hatch and water still gets in when it rains heavy
    There are vents in your rear locker to the engine room directly over the engine. If water is getting in to that locker then it could drain from the vents on to the engines
    @06Rinker270
    Thanks for suggesting the sound dampening. Just bought a 2014 310 EC and after a rain storm where I accidentally left the rear screen open, I noticed a huge "blister" full of water in the sound dampening material drooping over the engine.
    Could not figure out how it would have gotten in there.
    I will now look closely at how it sits in relationship to the gutters.
    Thanks again!
    I use the hose to rinse my floor all the time and still no water gets on the motors. Weird?
  • aero3113aero3113 Member Posts: 9,556 ✭✭✭✭✭
    I found the drains for the gutter of the hatch loose on my 242. I removed the plastic drains and reinstalled them with a fresh bead of 4200. I think water was seeping past the seal of the drain instead of going into the drain itself.
  • LaReaLaRea Member, Moderator Posts: 7,921 mod
    I'm curious how water in the engine room could keep the engines from starting.  What are the symptoms?  Starter batteries won't crank?  Or do they crank fine, but the engines won't start?  How long does it take before you can start them?
    A little water in the bilge is a normal part of life for most boats.  If water is dripping onto sensitive electronics or wiring, that's a different ball of wax.
    The insulation on my 270 under the hatch also gets wet when it rains.  I have also noticed something strange when I wax the topside with a white colored wax. The next heavy rain, any water in the bilge is white.  How it gets there I don't know. The forward bilge is always bone dry. Mystified.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,804 mod
    From what I've seen on the 342s, the water comes in thru the vents under the rear seat (or in rear locker) and gets the rotor/distributor cap wet.
    @Dream_Inn that is a definite possibility.  The fix though is to put vent hose on the ventsso that it hangs down just below the back ledge.  They are supposed to have vent hoses on them.
