Trouble removing Mercruiser Alpha One Gen. 2 outdrive
ercriss
Member Posts: 5 ✭
Transmission is in forward (full throttle)
Speedo tube removed
Trim rams disconnected
6 bolts removed
Outdrive is about 3/8" off the gasket but won't pop loose. I have gear oil seeping from the starboard side
Help?
Speedo tube removed
6 bolts removed
Help?
Put a pry bar between the transom and drive down where the trim rams are.
Lift up the drive at the bottom and drop down on the bar.
It probably the orings on the shaft coming though the gimbal bearing.
