Shift Control Tightness
SoulGravy
Member Posts: 54 ✭✭
2003 342 with 5.7 Mercruisers. The shift control box is very tight. It makes it even harder to maneuver in tight spaces, parking, etc. Had my mechanic replace shift cables at the end of last season to try and free it up. It didn't help and it seems to be getting worse. Any advice? Anyone replace with another brand? Link? Is it a DIY job?
Could be the ball detent. Do a google search for ball detent (or detent ball). You can actually do this while the boat is in the water (if you have to).
Just to help you out, here is another forum link of someone doing that posted pics:
http://www.clubsearay.com/index.php?threads/sticky-shifting-issue-5-0-mpi-bravo3.42470/
I have the same problem on my 330 where one throttle will slip back to idle speed until I get over 1500 rpm or so. Where on this binnacle is the "tightening screw" located?
See attached for throttle friction adjustment.
That's all the info there is for the friction adjustment. There is other info in the Mercruiser Commander 4000/4500 Controls manual that has installation/removal/assembly and components as well as shift/throttle cable installation.
You do have the same throttle. Take a close look and you will see the two screws to remove the chrome cover. There is a separate adjustment screw for each throttle.
I did this recently and note that the instructions say in part 3 to remove the 4 screws. I started to do one and it loosened then spun and then didn't tighten. uh ****, non-captive nuts underneath
While you have it apart, pull off the black covers and check the lube there. If one of those rocker arms aren't lubed it will be stiffer plus may not always drop back into the right home or neutral position and hit the switch right - the reason I went through this in the first place.
Re alignment, just dot with a sharpie the center of the cross head to the mounting bracket so they go back the same place.
As suggested above, while out, pop the black covers and apply a little grease inside to the arms as well, that solved my issue of neutral switch not being triggered as the arm wasn't springing back all the way.
