rough idle/stumbling
Had survey and sea trial Wednesday on a 2006 Crownline with 5.7 Merc with TKS (turnkey start). Not fuel injected. The boat sat for 3 years winterized and shrink wrapped. Took the boat out Wednesday and it ran great for about 15 minutes. I was starting, stopping, reversing, etc. All good. Surveyor had me do figure 8's and hit our wake. All was good until I stopped and brought it back to idle. It was stumbling and stalled. Had trouble getting it going again. It would start back up but stall when I tried to put it in gear. Finally got it going and was running fine at about 2500RPM. Went to my slip and had trouble getting it in with the stalling. We checked stuff on shore power and finished the survey. I went and back the trailer down and the owner drove the boat back to the ramp. They said it stalled as they pulled out of the slip but was fine after that. I was at the ramp and they had to change directions a few times and it sounded ok then.
My thoughts are water separator? Possibly bad fuel? Anything else I should look for? The boat is back on the trailer now and I likely won't be able to do anything to it until it is mine. I don't suspect anything serious as it ran fine before and even after that.
Thanks!
25 is a nice boat but having twins and wider beam makes a huge difference.
in few years I bet your will make the jump
Dana L. Scott
Vice President, Southeast Region Manager
Intercoastal Financial Group
Phone 443-220-9473
She’s awesome and very readily available for any questions I had along the process. I was very pleased! Tell her Josh mentioned her. I know she covers your territory, as I’m just down the Ohio from you!
