Water in the oil filter
Greetings to all,
just bought a 2005 Rinker 25 foot with a 350 mag mercruiser engine and a bravo III out Drive. The mechanic that tested the boat for me was also hired to perform the first service. When he removed the oil filter, a brown mud came out. Water in the filter! We checked cylinders, spark plugs were good and dry, compression was between 125 and 150 to the eight cylinders. Could it be a leak from the exhaust? Any other ideas? Thank you.
Could be multiple things that cause water in the oil. Cracked block, blown head gasket, exhaust flappers ect.
I am trying to order deck carpets, one vendor told me he has them but the info indicates 2007+ models and I can't tell from the blueprint. Thanks
Julius Pappas
