Horn Issues - Help
So the horn on my 280 worked perfectly last season and now this year it worked intermittently and now wont work at all. I pulled the dash real quick to make sure the switch was completely connected and it is. Is it possible that the horn itself just took a dump as it is electronic? I am not familiar with them so I am looking for some tips on where to start. anyone have any experience with this? @Cableguy Greg perhaps?
Boat Name: Knot A Worry
Take it apart, peel the sticker off the back and there’s another screw there.
Take some sandpaper and rub it between the points. You have to hold it down against the spring and get the paper in there. And then spray it all with wd40.
After i did all that, horn worked liked it was brand new.
On mine, a few of the screws were seized up. When I tried to remove them, I stripped the heads. I actually had to cut one with a hacksaw, so I'll have to replace the horn at some point.
