Tapping into ITC Light wiring
My plan on our 2014 310 EC is to open up the starboard radar arch plate above the blender and tap into the spreader light circuit and add a small task light.
Here's my problem: At the arch plate I can see all the wires going up to the spreader and there are two black (one thin and one thicker) - along with the assorted colored wires. Here's a pic...
Now, when I go and open up the ITC spreader plate and pull down the light, I can see that the blue/yellow wire goes to the light, but there are now three black wires (two small gauge and one bigger gauge).
I'm trying to figure out how it went from one thin/thick at the lower plate to two thin, one thick at the spreader plate.
I know I tap into the yellow/blue, but is it a safe bet to tap into the lower narrower black wire? I'd rather not just start cutting and checking continuity since that's more splicing to do -- so if anyone has gone through the experience it would be immensely helpful. Thanks!
Great suggestion about adding a 12v outlet and/or charger. I'll look into it, but the Admiral was already looking at the books and said I've spent too much money on projects this month already! But it keeps me busy and out of trouble. ;-)
@MichaelT - The Admiral knows all those small $ add up to big $$$$ after awhile - especially when I'm in "I can do that!" mode :-)
