342 Anchor rode
If I remember correct, the 342 came with:
30’ chain
130’ rode/line
anyone gone up to 200’ of rode/line?  Keeping the 30’ of chain still.
  • SoulGravySoulGravy Member Posts: 54 ✭✭
    I just took delivery yesterday of new rode from Dark Horse Marine. I got 200' of rope and 50' of chain.  I talked to the owner and took his advice.  According to him the Horizon windlass prefers 9/16" 3-strand nylon rode instead of 1/2".  He doesn't have this listed on the website.  He seemed like a good guy.  Refunded the money on the rode I returned (I ordered the wrong size) as soon as I shipped it and he shipped the new rode the same day I ordered it.
    I have 200 feet of 1/4 chain.
    Thx.  Just ordered 200’ of 1/2” 8 strand plaited line with 30’ of 1/4” G4 chain.
    Another update. My anchor roller has been loose for some time, so decided to fix that too. I ended up cutting a chunk out of the glassed in wall at the front berth to get access. The front most blt hole was getting wallowed out from being loose: the reason for being loose was the nut/washer crushing into the fiberglass. No wood core at that point. Oversize drilled and epoxied in a bronze bushing to accept the 3/8” bolt. In the rode area, I added a 3”w x 9”L x 1/4” thick Al backing plate. To compensate for the front most bolt area being thinner (gap with al plate) I filled with marine epoxy putty as the ‘shim’. Replaced the 2” screws with 3” long ones. Solid as a rock now!
    The piece I cut to get access I will caulk and reinstall with some flat Al pieces and screw it on.
    I also added the backing plate to the anchor locker cleat too.
    Very nice upgrade I will have to do same as I see mine does move a little.
    Very smart modification!
    Thanks for the pics! Always wondered what it looked like up there. Great upgrade, glad it worked out!
    Been thinking of doing that exact upgrade. Should have done it last year when I took the v bert apart to do my LED nav lights and seal the anchor locker......nice job
    Your video on taking apart that v-berth was a huge help!
    I was going to add a thru hull drain for those hoses I added to the windlass box drains. Might do one through the bottom and connect to the existing drain hose.
