Location of Bilge Water Level Alarm
Quick question regarding the location of my bilge water level alarm on a 2011 Rinker 360. It seems to me that it is way too high to be of any use. If the water level gets high enough to trigger the alarm, I don't think there will be much time to solve the problem, plus it means the bilge pump is not working or is overwhelmed with the quantity of water. I plan on moving the alarm to a lower location so that I will hear it before the water level gets too high. Do you guys think the existing/factory location for the bilge alarm is correct and why? Thank you.
https://www.law.cornell.edu/cfr/text/46/182.530
You can move it. If you do not like the location.
