tongue weight
floater212
Confirm Email, Member Posts: 121 ✭✭
how does the tongue weight react too light of a load and too heavy of a load? everyone says mine seems to need more weight, seesawing after bumps, but there is no way i can even budge the tongue up so i'm thinking too much weight.... any info would be helpful. 2005 rinker 212 rx1 heavy single axle...about 3500lbs for boat.
Here is a link on how to figure tongue weight of your trailer. How are your shocks on your tow vehicle? Just a thought. I have used the commercial scale method of weighing truck with boat hooked up, but don't have trailer wheel on the scale. Then unhook boat trailer from truck. Difference is tongue weight.
https://www.etrailer.com/faq-how-to-determine-trailer-tongue-weight.aspx
Too light a tongue weight usually causes the trailer to sway from side to side.
If you can barely lift the tongue then I assume you have a least 200 lbs load on the tongue which IMO should be fine for a Rinker 212.
A general rule is to have 5-7% of the gross weight on the tongue.
There are two ways to alter the tongue weight. Move the winch post to alter the position of the boat on the bunks/rollers or move the axle assembly forward or rearward. If moving the axle assembly it should not need to be moved 6" either way or something is off.
My friend had a swaying trailer one time and we were at a total loss as to why it was swaying until we realized that one side of the axle assembly was 1" more rearward that the other - and this was right from the factory!
Differences regarding side-to-side swaying can be caused by differences (side-to-side) in the bearings, springs/torsion bars and/or different heights/positions of the bunks or rollers.
This year my friends 2018 Waverunner on a LoadRite trailer seemed a bit off (erratic swaying on occasion). Turned out the starboard bunk system adjustment bracket was two bolt holes down on the front of its bunk and one adjustment bolt hole down on the rear of bunk attachment bracket as compared to the port side of the trailer. Equalizing these stopped the swaying.
Does your ball mount on the receiver match the tongue receptacle properly? Does your hitch bar match the receptacle of your vehicle properly, no clanking/banging while underway?
@212rowboat - given your generally superior level of expertise I am sure you have ruled-out most of this already.....just my 2 cents.
having a single axle as you've said indicates to me you're running the trailer that came with the boat- as a single 5200# axle costs more than two 2800# axles or even two 3500# axles..... and you ain't no fool, Sir, so... it's a stock one... a single axle is easier to trail and launch in most cases, but the benefit doesn't outweigh the costs.
the see-saw isn't because of an improperly set up trailer in this case, as that trailer has risers and brackets hard welded to the frame- it was engineered specifically for that boat, to include the tower's location (though it actually is bolted to the frame)...
so... just a guess here, but an educated one- seeing as how i've talked myself into that trailer being stock made for the boat: the brakes. man, i hate those things... when is the last time you changed fluid or shoes? it is pressure actuated akin to surge brakes and hitting a bump does guess what?
how big is your tow pig? I used a 3/4 ton truck and i don't trailer far at all- literally a 1/4 mile each way.... but... it can (and has) handled that boat with ease w/o brake assists on long hauls... it comes down to a question of safety if your rig is a weekend warrior, or legalities for trailers over certain weights... what i'd suggest to see is to disengage the brakes- by opening the lines and draining them.... see if the issue persists and if it does, it isn't brakes.... if it doesn't, you can either recover them, or replace them with electric over hydraulic...
another way to test to a degree is to shift into reverse as soon as you come to a complete stop and tap the throttle rather hard.. the trailer should roll freely, but if it fights you even for a moment (and it should only for a moment), chances are the brakes are grabby.....
Dave
