air conditioner size
Hello all,
been lurking on here for awhile and decided to join. I am a new owner of a new to me 99 270 fv. it is equipped with a gen but no air or heat. what size hvac do I need? when I install it do I have to put another sea valve in or can I wye of off the sea water supply line?
Best Answer
MarkB
Member Posts: 4,000 ✭✭✭✭✭
The AC that comes with the 260EC is 7,000 Btu. I'm not sure if my 2011 model came with that size or if it's bigger, but it's more than enough to heat or cool the cabin quickly. You should probably put in a separate water supply and you will need a return drain port.Boat Name: King Kong
7000 is correct. Which unit are you looking at?
http://www.marinaire.com/Marine-air-conditioner-6000-btu-110V-p/msba6k2.htm
this is the one that is at my home waiting to be installed in the spring.
X
Very quiet, Toshiba compressor on these units. Much more advanced then the Dometic units!
The MarinAire unit is so quiet it's hard to tell it's running with the genny. We've run it about 30 hours now - it's ice cold (40° at the outlet). The 280EC (and the 260 I'm sure) have one vent that blows under the steps into the cabin. I want to add a secondary vent - the cooling is most needed against the firewall in the mid berth. I know eventually it'll be felt there - but with a fan and a vent we could better balance the temperatures.
in the aft bed is their a hvac grill...also /not sure on your year..under the aft mattress
there is a small compartment..has the shower sump..bilge pump and where the sea strainer for ac and pump is located
sorry to ask but you have looked the boat all over
but he never posted again
