HOLDING TANK FILTERS
Just received my Voker holding tank filter and noticed there is no mention of any kind of relief valve in the instructions like the "Big Orange" has. This may be why it was considerably cheaper. Just wondering if anyone on here has had a problem with it clogging. Thinking maybe I'll add a tee with a cap, or valve between the tank and filter to open when tank is being pumped out.
Just make your own. Cost is about $20 and then $5 or so to refill.
Or the air vent filters that you can buy at home depot.
https://www.homedepot.com/p/4-in-x-12-in-Vent-Filters-12-Pack-WVENT/100351670
Just curious, did it not keep the smell down? or did it not allow air to flow during pump out? or was it just the way it mounted?
May have been location of the filter (or tank too full). I'm always concerned about air flow with mine during pump out. Most of our pump outs really pull it fast. I have added the large valve on the top of the tank, but I think it waits for a bit before it reliefs pressure. I should just add another one around the filter.
The tank saver relief valve does take a couple of seconds to engage but between that, the oem vent and the vent on my Big Orange we never had a problem.
