2005 342 Starboard Gas leak
                    Hi Rinker Boaters,
I have a 2005 342 that is leaking gas from the starboard. Has anyone experienced or heard of this issue?
Does anyone have a owners manual or fuel system schematic that shows the component and connections that makeup the fuel system?
Please help!!!
Boater down.
Thanks in advance
Please help!!!
Boater down.
Thanks in advance
2005 Rinker 342 - Maryland
As noted, pull the ice maker and you can get to the deck plate for access too.
I’d be looking at the fuel lines personally. Where are you seeing the gas? Or just smelling it?
Thanks all. It's been venting for a few days now. Once the smell is completely out I'll remove the frig and dismantle the cabin. Hopefully I can get this resolved before the holiday.
If anyone have any schematics please share.
Thanks all for the input!!!!
If the tank itself is leaking then as noted above you need to have it professionally emptied out. Expecting the gas to just evaporate is a major hazard. All the AC and DC power should be shut off.
Andy
