Waste Tank Woes
Willhound
Member Posts: 4,221 ✭✭✭✭✭
Doing some maintenance and inspection this morning I found my waste tank had come loose and was sitting atop the mounts. We got some heavy waves coming back from a trip last weekend. I was able to pry it back into place but as I did I heard a slight "crack"......
Just right above the outlet hose connection a small hole opened up. Not quite a full stream but mire than a dribble. I can see where the position of the hose has been putting upward pressure on the tank. I suspect its been leaking slightly for quite some time as I noticed a bit of staining in that area earlier this year. I intend to change the tank of course but would prefer to wait for fall as the batteries and who knows what else will have to come out. We rarely use it and never for a "big" job. So thinking of a temporary patch.
Ideas? My first thought is rough up the area and try some fibreglass cloth and resin. Other idea I had was to drill out a larger hole where the leak is and install an expansion plug but I worry about the split opening up wider.
As for the tank, I'll do a search but does anybody know off hand the make? Is it a Moeller? Dimensions are 14 wide x 15 high x 34 long. I'd even consider a smaller tank for the bit we use it.
If you do a fiberglass patch, drill a hole (maybe 2-3 mm) at the end of the crack. That will help stop the crack from propagating.
Wait, how much is a new tank?
It's not the cost, it's going to be changed. But would like to wait until end of season because all my batteries and probably a few other things are going to have to come out to change it.
I had thought that the tank would drain down over the last several days but when I drilled a relief hole at the top of the crack I discovered otherwise. Don't worry. Mostly water. No solids in the tank. Still stinky though.
So work is stopping until I can get a pump out. We get unlimited pump outs at our Marina but only on Thursdays. There's no permanent pump out dock. Once a week they pull a portable unit around all the docks. So Thursday night after work I'll try again. Going to try the product below. Made and sold by Permatex in the US. This is Canadian branding but same kit. Seen good reviews on it. Just need to clog that leak for the rest of the season until a tank change and will do all hoses at the same time.
Speaking of which....as you can see on the pics, the clamps on the discharge hose are turned in such a way that it is almost impossible to get them off without cutting the hose. Wondered if this is on purpose to discourage people from pulling the line off and dumping the tank?
https://www.amazon.com/Flex-Tape-Rubberized-Waterproof-Black/dp/B01N5Q3G8H/
@Willhound - I can almost smell the odor of that "liquid" squirting out of your tank. Its never ever a fun job when you start messing with head plumbing.
In the meantime, does anybody happen to know who supplied the tanks for 2000 era Rinkers? I'm having a devil of a time finding a matching tank. All of the suppliers like Todd, Moeller, Scepter and pretty much the rest I'm seeing all have the in and out and vent on one end. Mine is top feed in, top vent and end drain and I'd prefer not to have to change out all the hoses.
https://www.dometic.com/en/se/products/hygiene-and-sanitation/sanitation/holding-tanks/dometic-dht88l-_-25304
