Best Way to Bleed Air from A/C System?
 glshoemaker
                    Member Posts: 25 ✭
glshoemaker
                    Member Posts: 25 ✭
                    Alas, my 342FV's A/C system has "evil air" in the lines.  The wall unit is telling me high-pressure, turn it off now!
I'd greatly appreciate any expertise you may have concerning best procedure to bleed this unwanted air out of the system. Is there an easy method? Hopefully.... Thanks!
You can also crack the filter open, with seacock open, let the air bleed out. The tee piece with a bleed valve is the easiest way though.
