Bluetooth adapters/ wash down pump recommendations?
 jbschmalz23
                    Member Posts: 219 ✭✭✭
jbschmalz23
             A few questions. The Sony CD player in my 310 has the USB port for the iPhone and an aux port. But when the iPhone is hooked to the USB port, I can’t change the song when on amazon music etc from the helm remote. I know there are some Bluetooth adapters out there that you can just plug into the aux port. Anyone have a good one they recommend? I just don’t want one that takes batteries. 2nd question. I like to use the river water water to wash the boat. My 310 doesn’t have the wash down pump option. Has anyone rigged up one of the pumps and just stick the line down in the water and plugged into 12v, and just used one as a portable setup, or will it even work that way? Any one pump you recommend? Thanks all!
For the washdown - I've done this to run a livewell on a paddleboard in the Keys. You need a pump for higher pressure though - and that's where the challenge starts. High pressure pumps are usually diaphragm pumps, and not typically submersible. Rule makes one that has a hose, alligator clips, and a spray nozzle, but figuring in the 5 feet of head and a long hose - performance will suck. The best solution is a built-in washdown pump with it's own through hull, or sharing a through hull with another system that won't be operated simultaneously.
https://www.amazon.com/dp/B07FSF4HJS/ref=cm_sw_r_cp_api_HS.GBbB2JWKYQ
