2004 FV 342 performance issue
throwing this out there .... 2004 FV 342 , 5.7L Horizons , bravo 3 ... very reputable Merc mechanics have looked at it found nothing, no alarms, no guardian mode .... symptom; with load or without (people) , cannot get above 3000 rpm on both motors, mechanic found bad water pressure sensor, replaced but still have problem, heres the kicker, seems intermittent , ran last weekend 28'ish knots all the way home, today had the problem, ran tug boat speed all day .... any ideas? anyone?
"Next Adventure" 2004 Rinker Fiesta Vee 342 , FWC Horizon Mercs, Blue Imron Hull
Just tossing it out there. Hope you figure it out. Sounds like something any of us could encounter and would be good to know cause/cure.
all is fixed according to mechanics.
- seperate issues on each engine.
- stbd engine started stalling on them on sea trialing/testing. replaced distributor and coil.
- port engine: they found y-pipe flapper gone, they scoped the engine couldnt find pieces of flapper , they concluded its stuck in outdrive somewhere. exhaust blockage. They bypassed exhaust bellows to exit outside of drive.
--- achieved 36kts at 4200rpm
--- they advised that due to age of boat, 2004 , 10% hp reduction due to ethanol and orginal 24p props, next year go to 22p props, will put motors in sweet spot
more to come after labor day weekend, we have an overnight trip scheduled
dropping a pitch will raise your rpm and sometime keep it drop wot
