Rinker 232 Captiva BR Swim Platform
I purchased an original swim platform from Rinker. I was assuming there would be at least two support poles from the platform to the bottom of the transom. None were included and there weren't any lag bolts either in the package.
Rinker is telling me that for the 232 Captiva, no support poles are required for the install, just the nine 3/8" bolts that will be drilled through the back hull. Can someone please provide a photo of your OEM Rinker Swim Platform for verification.
I've attached some pictures of the platform and one that I found on the internet but I cannot tell if support poles are installed.
Thanks.
Thanks.
@boltzie
You have the same boat as mine, even color. I also put Seadek on swim platform and love it. I have a factory installed swim platform and it has no support poles like you are stating. I don't think it needs support poles if installed like factory swim platform.
Rob
Thoughts?
Boat: 2004 232 Capitva CC
Boat Name: Mixed Nutz
@Handyman342 are you referring to a thicker square washer like used with Unistrut? I use these often but are galvanized, not stainless steel. Do you see any issue with this?
i know this post is a little old but im really looking hard to find the original Rinker 232 Swimplatform for my Boat. Does anybody have one for sale or does anybody know where i can get it from?
Thank you
https://www.greatlakesskipper.com/rinker-boat-swim-platform-26-flotilla-72-x-35-1-2-inch-fiberglass
Not sure if that would work, or modified to fit.
