INTERMITTENT CHARGING
2000 FV242, 5.7 Mercruiser. Last time out I watched my voltage keep dropping. When Battery #2 hit 10 volts, I switched to battery #1 and made it back. When I got home, I plugged in the onboard charger and brought both batteries back to full charge. Srarted the engine and multi-meter said altenator putting out 14.5 volts, and reading 12.5 volts at both batteries, 12.7 with motor stopped. I removed the battery isolator and did a diode test between the input and both outputs, and it passed. Put the isolator back in, and now reading 13.5 - 13.7 volts at both batteries. Is it possible for the isolator to stop working and then start working? I would love to believe it was just a bad connection, but I'm usually not that lucky!
I should check all my connections next time I have time to get into the bilge.
