12 volt outlet in cabin doesn’t work
luvinlife
Member Posts: 501 ✭✭✭
The 12 V outlet in the cabin of my 270 does not work. I bought a replacement outlet but it still doesn’t work. I don’t see a fuse behind it I wonder if there is a circuit breaker somewhere that I can’t find
Other searches for this is "fridge doesn't work away from shore power" and the like.
For sure it's either an inline fuse or a breaker. Did you check under the helm, there's many pop up breakers. Otherwise, can't you get behind the 12V plug in the TV cabinet, and check if there's an inline fuse? If not, run a new wire.
into another circuit.
