GFI Replacement + Charger Issue
picturethis
Member Posts: 103 ✭✭
I have a GFI outlet in my battery switch box that wont reset. The plug is still hot, my question is do I really need to replace it since it still works?? I seldom use it for anything.
Not sure if its a related issue but........
I also noticed that the battery charger (Guest 2615) doesnt hum anymore when its plugged in to shore power but its still charging, It used to make a noise when hooked up
Everything is stock to the boat
I am a new boater with my first boat, thats why some of my questions seem dumb
What is making it trip (short, ground, etc.)?
What is down stream from the outlet that is also out as a result?
GFCI do go bad and you replace them. It's not common for a working GFCI to trip on it's own. At home if this is happening something in the line is causing it to sense a voltage spike or "ground fault" and should be investigated if it continues to happen over and over.
I stick by my original recommendation...If the features of the GFCI are not functioning then replace it. Not expensive or hard to swap out.
the test button is stuck out , it wont push in to test but the plug does work
Since the plug in wired into the battery switch box will it cause other electrical gremlins because of the non working gfi?
Everything else electicly works on the boat
