chart plotting....what to use/buy
 04FV270riverrat
                    Member Posts: 268 ✭✭✭
04FV270riverrat
                    So we want to start taking our 270 FV on some trips to different lakes and places i.e. LOTO, Put In Bay, Florida, etc. I currently do not have a chart plotter except for the Navionics app on my phone. What's the most economical way to get a chart plotter on my boat? I wouldn't mind using a tablet with the navionics app, but I'm assuming that would need a cell signal or wifi to work.
What is a good budget one to buy?
I used navionics on an android tablet for a 20 hour (round trip) voyage. It was my backup chart plotter to the one I installed (dragonfly 7) and both of them read the exact same the entire time. The only trouble I had was in rough waves my mount for the tablet wasn't strong enough!
I recently got a Samsung tablet and i'm trying out various apps . At the moment I'm using iboating for setting waypoints & routes etc., Marine Ways as a backup and to see actual NOAA charts, Waterway Guide for marina and Anchorage info, and a NOAA app for local weather.
I keep all the apps running and just switch as needed.
I mount the tablet on the old lowrance 2400 , that came with the boat, with a couple of velcro strips.
The maps are downloaded so all I need is the GPS signal.
I would try some free alternatives to navionics. I think they charge to much for maps. My total cost for maps and apps is less than $20.
And of course I can use the tablet for all sorts of other things.
gps is a must
garmin is my fav
connected to a Simrad GO7 or something similar that can connect and display the Vessel View info.
The biggest benefit is seeing miles-per-gallon in real time. That one number conveys a huge amount of diagnostic information because it encompasses not just the engines, but also the drives, props and hull. For example, if your mpg suddenly drops by 20% from where you normally see it, you know something's wrong even if the engine gauges look okay.
