Normal oil pressure 8.2L MAG
determined
Member Posts: 16 ✭✭
Hello, what's the normal operating oil pressure for 8.2L MAG. I have a 2012 Rinker 360 with these motors.
Warmed up at idle, the PSI is 61 psi (port), 54 psi (starboard). Is this normal?
Thank you.
Thank you.
Best Answers
Michael T
Member Posts: 7,241 ✭✭✭✭✭
When you say "warmed-up" I'm not sure exactly what you mean but I suspect it is something like what I used to do - I would wait about 10 minutes at idle before reading the engine oil psi thus giving both engines enough time to absolutely reach idle operating temperatures.
I may be able to find a shot of a screen grab of my vesselview here on the forum from my 2014 EC 360's 502 Mags. If not when I return home in two weeks I will have the info.
From memory there was not much difference between the psi of the two engines - maybe a slight operating fluctuation of one or two psi - definitely not 7 psi. Is a difference of 7 psi worrisome? I don't think so as Mercury themselves state there can be a 5% difference on the operating specifications engine to engine. -
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
Is all of this on faria analog gauges? Or would a 2012 boat have digital smartcraft?07' Cruisers 390 (Previous Rinker's: 06' 342EC & 01' 310FV) -
F1100 Member Posts: 292 ✭✭✭
There is no issue with that variance. Its two separate engines, 2 different pumps, 2 different sending units, 2 different gauges. That is more than enough oil pressure either way.
1993 300 FIESTA VEE TWIN 5.7L ALPHA GEN 2 -
Michael T
Also there can be variance with the oil pressure sensor. A while back I posted trouble we had with the water pressure sending sensors on one of my 2014 Mag 502s. The original sensor became erratic and it took three more to get a reliable reading. -
determined
Member Posts: 16 ✭✭
Sorry If I'm repeating myself, I wanted to thank everyone for their insightful answers.
It will be interesting to see if the fresh oil makes a difference. I won't know until spring as I'm wintering the boat at the moment. Season is always to short. Some asked if I had analog or smartcraft. This is a smartcraft system. Honestly, I think I preferred the analogue gauges, easier to see everything in one glance without going through screen after screen after screen. Wishing you a terrific winter!
Thank you gentlemen for your advice.
