Winterizing Rinker 312
Weber
Member Posts: 249 ✭✭✭
I drained the water system down, filled the water tank with antifreeze and ran it through the water system.
I used the air pump on the engines, and followed the instructions to purge the water out.
I added antifreeze to all the bilge pumps, and drains.
I just need to figure out what to do with the ac inlet, and toliet?
Any help with those? And anything I'm missing?
Sin or Swim - Rinker 312
Same with the genny.
Water system filled the tank and ran each faucet until pink came out of both hot and cold.
Engines have the air pump system, pumped them up until all the water drained. Did it a few times over a couple days to be sure.
Anything else I'm missing for freeze protection?
