Engine shutdown alarm
Member Posts: 3,023 ✭✭✭✭
Greetings,
Having an issue recently with a faulty IAC, coming back to idle resulted in the engine shutting off and with all the background noise of the lock and water I didn't realize immediately until I looked at the tach and saw it dead. So it would be good to have an alternative buzzer sounding if the ignition is on but motor not running.
Has anyone setup such an engine shutdown alarm on their vessel?
I does on start up but not when you stall??
