Out drive oil filling
 skennelly
                    Member Posts: 2,196 ✭✭✭✭
skennelly
                    Does anyone use an electric pump to pump drive oil back in?  I'm sick of the hand pump method...takes so long.
If do can post the pump type
I found the trick is to cut the last inch off the hose, make sure the end of hose and pump are clean of oil, then install. It'll be tight and will stay on. Believe me, I've been there done it way too many times. & for me, I am out on a raft floating in the water doing mine. That makes it even more interesting.
as an afterthought, though, i just bout a gallon one at Lowes yesterday for $12 i think it was, to spray bleach on wood that's building mold from the storm... so.. it's not like you're out that much at all.
