Rinker 260 EC Raw Water Hose replacement at Transom Bravo 3
I removed the old water hose at the transom assembly but how the heck do you access the Water Inlet housing behind the engine and transom to get the new hose insert screwed in? It is virtually impossible to reach your hand back there and I have yet to find a tool that will fit to unscrew the two screws on the water inlet housing. Seems that Rinker/Mercruiser would make it a little easier to change a darn water hose without having to remove an engine to get at it. Any suggestions, advice??
For the hose you are replacing. Make sure it is the ‘new’ one with the hard plastic end going towards the transom.
