LOST ELECTRICAL POWER
I was idiling on the trailer to bring the motor up to temp so I could winterize the motor (2000 FV 242 with 5.7 Mercruiser EFI) when it stalled. Turned the key and nothing. I have no ignition, fuel pump, blower, radio, or anything 12volt except the power trim, which I believe is wired direct to the battery. I tried the 50 amp breaker on the top of the motor, checked all the 12v breakers and nothing was tripped. Any ideas?
A fat cable, likely 2ga runs to helm... They build a beautiful patina (not) on themselves and often snap. Your rig is a 2000, and it's prime for such a condition.
If this is it, here is some free advice: either abandon it and run new main power line to helm, or stand by for huge headaches. I'm pretty sure the line was installed before the upper and lower shell was joined and its near impossible to get at after theyre connected. Fishing a new line in is pretty easy compared to removing speakers, insets, other items to get to it.
Art
"Main harness seems tight, I have power coming out of the battery switch, but no power at the 50 amp main breaker on top of the engine. Kill switch wouldn't effect the lights radio or blower."
With power coming out of battery switch, I would look for a 15 amp starting circuit fuse. I had a short to ground in this 12vdc circuit with all the same problems. After finding a blown 15amp fuse, I'd replace it and turn the ignition key and it would immediately blow. the problem was the diode light in the dash compass!!!!! unbelieveable! Without that circuit working correctly, no other relays will energize to distribute power, i think that's why you have no power at the 50 amp main.
I had found a print for this but of course I can't find it now. I'll look again for it.
Art
BTW- I was idling on the middle of the lake, after running all day and the boat just stopped dead. same thing you described.
maybe you should at least drain your block and headers. If it's getting that cold up there.
https://www.ezacdc.com/Scripts/wire-color.htm
It will save me time probing with the meter next time.
Art
