so...where do these go?
rasbury
Member Posts: 8,715 ✭✭✭✭✭
I would have posted this on my thread for pulling my engine but I think everyone is so tired of looking at that, I figured I better start a new one...perhaps a moderator can merge it onto that thead as it has like 5000 plus views and hopefully might help someone, if nothing else like I was told often enough, take it to a shop.
Anyway....so I have these neat little tags with ties so when I take stuff apart, I generally know where stuff goes back. It is darn shame I did not do it on the wires in the bilge. There just aren't that many of them on an engine pull, certainly I'd remember where they all go.... I sure hope someone here does...
OK- ground wires I'd think are pretty easy. I have a bolt down on the back coupler housing....there is a ground wire from a block mounted on the transom right by the trim pump...there are two coming from the main harness running along side of the motor. So, I assume all of them go there.
There sure are a heck of a lot of positive wires to deal with. On my two battery set up which are not done in parallel, one battery has a plain positive and negative connectors on them, can't add anything to them. The other battery, which I assume is my starter battery, has a post to add other positive connections to. So, I assume I have one that goes to my genny and that runs towards the harness coming out of the genny so I think I have that one...did not look if there was a ground but did not pull anything off the ground side. I have one really long one that goes up to the battery switch, assume that goes to that battery. I have one on the harness that runs along the motor, assume that one goes to the starter. I have one other one with a weird post on it that I'm sure goes to the trim pump which I pulled out. Sound about right? I have various pictures...
The wire that comes from the mercathode on mounted on the transom assembly, don't see where that plugs into...
So, on the trim senders....I recall two wires went to the top of the motor.....there is another harness that runs along the transom I had to pull apart to get two other wires for those senders out of....don't seem to really identify on the wires which are for what....any clue on those???
On the trim pump, is there a ground for that? I have a loose bolt on the frame that something went to, assume it is a ground but can't tell by wire lengths or where they lay which ground would go there.
Seems I have created a bit of a mess.
oh, the last one is my new great grand daughter and threw that in for sympathy. The one picture above with the wire tied around the water strainer, I can't figure out what that is- don't know if it was hooked up to anything. It has a connector on it that the other end the wire is pulled out of...looks like it went back towards the back of the motor, thought it might go to the trim pump. I don't see a bare wire anywhere that this would have pulled off of....how do I possible solve this mess??
Thanks all,
For the most part, anything that is positive goes to the one battery post that I can put wires back on. I have the geeny positive. I have a positive that goes to the starter, just one wire there correct? There are a total of three wires that goes up to the battery switch. One, on each battery . There is a third wire coming down from the battery switch that goes somewhere- either would have to go to the battery on that extra post or to the starter...I assume to the battery correct? So the main battery would have two wires going up into the battery switch if so...
I have a positive and negative bundle that would look like they would go to the trim pump.
I would assume all ground wires are going to go to the back side of the motor on the coupler housing....again, did not pull any ground wires off the batteries.
Trim sensor wires- have two that go to a harness that runs along the transom and two that plug in atop the motor. On a meter, how do I tell which wires go to which sensor? Which sensor goes to which plug ins??
The only real mystery wire I have, and it may not have been connected to anything, along the main harness running along side of the motor, there is one wire, only piece of wire in a loom coming off the main harness and it is spliced in with a crappy connector. On the other end, there is a connector and the wire has been pulled out of it. I don't see any single bare wire that this would have been pulled out of...no clue where that might have gone to....here is a pic of that wire: So, getting close to burning some gas here...would like to dunk it at the marina and spend the night next weekend if it's not to cole....might be in the 60's, brrrr~!
