Buoy reminders on chartplotter
LaRea
Member, Moderator Posts: 7,999 mod
Most boaters know "red right returning." As a visual aid, some captains use a manual device like the one shown below ... rotate it so the red buoy is on the correct side depending on your situation. It made me wonder: do any chartplotters offer this function digitally?
Any chartplotter capable of auto-routing should be able to do this easily. If I'm navigating a river or narrow inlet, it could deduce my course relative to the channel, and draw reference buoys in the top corners of the display. There might be rare times when the computer can't figure it out, but I think it would usually be pretty clear.
I'm sure the lawyers would make them write "ADVISORY" or something like that.
Is anybody doing this?
But the plastic has two flaws. You have to remember to set it each time the buoy convention changes. And, to set it, you have to actually know the buoy convention (which isn't always obvious).
I was just thinking it would be easy for manufacturers to add. (Raymarine, Garmin, if you're reading this -- you're welcome. I want a discount on my next purchase.)
