AC Fan
CrewLounge
Member Posts: 92 ✭✭
My AC/HEAT fan runs all the time on my 2002 342. I would like for it to run only when the compressor runs similar to household units. It has the Passport I/O electronic controller. I can set the fan speed to automatic, but it still runs all the time. I can adjust fan speeds as well. Any ideas?
As RY said, there is a setting that you can change. Take a look in the manual for programmable parameters. You usually access it by holding the power button on, then a P-1 will show up. It is usually one of the last settings & state something like cycle fan with compressor. Pretty simple change.
Welcome to the forum!
Len & Robyn 342 FV Freebird
