Shift cable adjustement
rasbury
Member Posts: 8,866 ✭✭✭✭✭
So, sitting here wrapping things up with the boat on the street. As far as I know when I first started the boat, the drive shafts were not turning. Once everything was running and warmed up I wanted to put into forward and Reverse to make sure it was going in and out of gear ok. Seemed to but I obviously was not paying attention to rotation....in neuteral it is is in gear... Outer shaft is turning clockwise....when I put it forward, neuteral and reverse it continues the same...it's a new shift cable....I would think if it is adjustment by putting it in forward or reverse at some point it would go into neutral or at least rotate the other way indicating adjustment required?
