Time for a gauge replacement
Hi guys!
Over the winter I plan on overhauling/upgrading a few things on my 2000 180 Bowrider.
Firstly, I need new gauges. Does anyone know what type of gauges Rinker used on my boat? I carefully labeled all the wires and uninstalled the factory gauges today. They have black faces with white print and have blue on them as well. The back of the gauges are a light mint green and there is no indication of who the manufacturer is.
What could I upgrade to that would be reliable, accurate, and possibly LED backlit?
I need speedo, tach, trim, fuel, volts, temp and oil pressure.
Attached is a pic of the gauges (sorry for quality)
Also, what would you recommend as a replacement for the three factory switches for bilge, Nav lights, and blower?
go to their page and look at their options.. you can even look up past models to verify. If I wasn't doing something else right now I'd find a link for you... I may be able to come back in a while and post one.. I went to Faria's webpage, and searched around until I found link to past models, and matched the ones I had up with a model number, so i know it's possible.
http://www.seastarsolutions.com/products/instrumentation/instrumentation/premier-pro-black/
Thanks RY! Plan on color matching the panels to the steering wheel over the winter.
http://precisionstar.ca
That looks really nice!
thanks guys!
