Easy Up Swim Handles
Willhound
Member Posts: 4,236 ✭✭✭✭✭
Wondering if anyone has experience with mounting or using these? Any input good or bad?
http://www.easyupswimhandles.com/
in particular the "P" shape handles.
We will likely be adding a custom swim platform to our 2000 FV270 this year and need an option to both aid in boarding from the dock and also when climbing out of the water. Admiral sometimes has balance issues and a bad back so likes to have something sturdy to hang on to when boarding and disembarking.
In particular, I'm wondering if the handles "lock" into the orientation they are placed, or will they swing from side to side, i.e. swivel?
As far as the platform, I realize these guys are affiliated with Swimplatforms.com but I have a more local option that I will likely use for the platform. When you take into account exchange and shipping the cost of the platform from there gets crazy so I'd look at adding these myself.
Now if only I could get some feedback on the product. While searching it I came across the patent documents showing it was applied for in 2010/11 and only finally granted in 2015, so relatively new. It appears the original idea stemmed from swimming pool ladders and rails. Simple really, a boater saw a need for a product that didn't exist and was able to take it to production. Anybody else have any bright ideas they can retire on?
I have one like the Anglesey units mounted at the stern like most have as a grab handle just above the platform, my friends Bayliner has nothing and we were looking at something like mine too as there needs to be a grab handle. For us this works but if your admiral has mobility issues it sounds like you'll need something else.
I suggest a 4 rung ladder too for that extra depth first step, mine is 3 that for the 5'2" admiral can be a stretch and trying to find one that will fit folded in the ladder store is a challenge. If you are doing a new and custom platform your options are pretty well open.
http://www.nauticexpo.com/prod/nautinox/product-23300-268017.html
Veering back on-topic ... good point about dropping the handles overboard. Have you considered just tying a rope to use as a handhold when re-boarding the swim platform?
I agree the dropping overboard factor is a consideration, but most of the places I can think to use them are shallow and the fact that they are removable just leaving a little flush mount is a plus for me. They should easily store under the rear seat. Might also consider davits in future, and this system would allow me to still do that.
Toronto Boat Show is in a couple of weeks, maybe I'll see something there but if I go ahead in the spring with the platform, I've pretty much convinced myself I need these too and can report back.
They use a socket with collar on top and a matching collar underneath. I think as long as you drill down thru the platform at 90 degrees you'd be ok.
Yeah, that big a$$ platform has been awesome! Best addition ever to the boat and zero effect on handling or getting on plane. Had to watch backing into the slip at first but all good now. Two deck chairs and a small table and still room for others to stand or walk by.
