Engine Room Cameras - Anyone done it before
After experiencing a raw-water hose pop off whilst underway and only discovering it when steam started pouring out the vent .... am thinking of getting a pair of cameras installed in the engine bay with a screen at the helm. Has anyone done an install before and what is good placement for a two engine setup. Thanks.
btw : cameras are bog-standard twin reverse cams for trucks etc with infrared.
(1) You can hard wire cameras into a compatible multi function displays. These are usually self powered by the display unit.
(2) You can purchase a hardwired "back-up" camera, which may have its own display screen included. These need to be hooked to power, and cables run for the display unit, wherever you should chose to mount it.
(3) Or...By a "Blink" rechargable wifi camera. no wires, a charge will last 2-3 months depending on use. You can bring the camera up on your phone or desktop or tablet. They have built in IR LEDS for darkness. They have motion sensor to alert you of motion on your boat or engine compartment. And you just need a good wifi signal, which most marinas should have. And...you can listen and talk through the camera. So when you are home watching TV on a Friday night, and someone decides to take a leak off your swim platform, not only will you be notified, you can tell the idiot to get off your boat.
