Cleat Installation
I'm in the mood for some winter projects and thought about adding some amidship cleats. I've done some searches on the forum and based on that would like advice on what I should do. My plan...
I was going to use a 316 Stainless Steel 8" Stud Mount Cleat (only two holes to drill versus four with "standard" cleats)...
...and back it with a 1/4" X 4" X 8" aluminum 6061 flat bar - bedded in 3M 4200 adhesive sealant.
Does this set up sound OK?
I've read some comments about detrimental galvanic reactions of mixing aluminum with stainless. Yeah or nay? And if not aluminum - what should I use as a backer? (Thinking that a stainless backer would be heII to drill through with the tools I have at hand.)
Post edited by raybo3 on
you don’t have water nor current to make corrosion a concern for that.
Amarine-made Boat Marine Stainless Steel 316 Pull up Cleat Flush Mount Cleat Lift - 8 Inch
https://www.amazon.com/dp/B016IBUS4W/ref=cm_sw_r_sms_tai_1OuqCbN3Z...
Atwood have one too. It would provide a cleaner look and out of the way especilaly if you don’t plan to use them all the time.
I did look at the pop-up and the fold-up. Others at my storage yard have had long term problems with pop-ups leaking and/or the springs failing. So I am shying away from those. As for the fold-up, I think those would be fine for smaller craft, but not for my application.
The one I had seen didn't have springs but just slide in and pull out and that would work for me - and no spring breakage concern.
