1995 Rinker Captiva 212 Bowrider Declaration of Conformity
LuisMirandaLuisMiranda Member Posts: 10
edited January 2019 in Rinker Support Q&A
I'm lokking for a Declaration of Conformity, with mesures, HIN and maximum power for my captiva 212, very urgent
Post edited by LuisMiranda on
Best Answers
  • TonyG13TonyG13 Member Posts: 1,393 ✭✭✭✭
    Answer ✓
    Send an email to Mallory Wagner with your HIN. She should be able to get you one. mwagner@rinkerboats.com
    Sorry, HIN= Hull number?
    Yes - Usually located (embossed) on the edge of the swim platform -- aft (rear) starboard (right) side of the hull. Make sure it matches what's on your paperwork.
  • Cableguy GregCableguy Greg Member Posts: 5,055 ✭✭✭✭✭
    Answer ✓
    Yes, Hull Identification Number
    Answer ✓
    Do you know how long it usualy take to get an answer from Mallory? thks
    She is usually pretty quick.
    It's usually under the helm.
    You probably won't find one.
    Under the U.S. Coast Guard regs, a capacity plate is only required for boats less than 20 feet powered with an inboard, outboard, or stern drive engine manufactured after November 1, 1972, and must display a capacity plate defining the safe load limits. Since your boat is greater than 20 - no requirement for a capacity plate.
    Now, for a "certification" plate,  don't know what Rinker was doing in 1995, but NMMA/ABYC certification is voluntary. So you might not have one. If you do, it's usually in the helm area.
  • WillhoundWillhound Member Posts: 4,226 ✭✭✭✭✭
    Welcome @LuisMiranda. Do you mean that you can't find the location? Or is it missing and you need it for registration? If missing, it'll be tougher.
    My 1998 232cc had one. It was 8 people or 1750 lbs. Any 212 that I ever saw had one.
    It is only "required" by US regs for boats less than 20 feet. That doesn't mean a manufacturer can't voluntarily place one on a vessel. A lot of states require them in excess of federal regulations, so that could be why you see them on larger vessels.
    Just sayin' not legally required (federally) in @LuisMiranda's situation.
    edited January 2019
    @TonyG13 that assumes he's in the US. A plate is absolutely required in Canada and most of Europe. Most European countries also require a CE certification in order to register the vessel and legally operate it. Guess we'll have to see where he's from if he comes back.
    @Willhound - Agree! I already assumed US, so my bad.
  • LuisMirandaLuisMiranda Member Posts: 10
    I Willhound, thks, I need it for registration... and I don't know what I can do...
    My don´t have and I need it!!! do you know how or were I can get one or some document with the same prupose?
    edited January 2019
    @LuisMiranda - Are you in - and the boat is used in - U.S. waters?
    If yes, then you can have a plate made. There are numerous on-line sources. Just beware you must supply accurate information. There are also on-line resources to tell you how to calculate the capacity of your specific boat to print out a proper plate.
    Here is a place that makes plates (decals)...
    https://www.replacementdecals.com/store/c/119-Create-Your-Own-Capacity-Decals.aspx
    As to the validity of whether you can have a homemade capacity plate, please refer to this from the US Coast Guard Auxiliary...
    http://help.cgaux.org/index.php?/Knowledgebase/Article/View/363/6/capacity-plate-requirement-on-boats
    Another thought: If in the US, have you taken a safe boating course from either the US Coast Guard Auxiliary or the US Power Squadrons? Both have a section in their courses regarding capacity limits and how to calculate them.
    No... I'm from Portugal... Europe, I realy need a valid source for the plate or official document can prove this capacity... for the registration
    Done... let's wait...
    No answer until now... :'( :'( :'(
