1995 Rinker Captiva 212 Bowrider Declaration of Conformity
I'm lokking for a Declaration of Conformity, with mesures, HIN and maximum power for my captiva 212, very urgent
Post edited by LuisMiranda on
Best Answers
TonyG13 Member Posts: 1,390 ✭✭✭✭
Yes - Usually located (embossed) on the edge of the swim platform -- aft (rear) starboard (right) side of the hull. Make sure it matches what's on your paperwork.LuisMiranda said:
Sorry, HIN= Hull number?Cableguy Greg said:Send an email to Mallory Wagner with your HIN. She should be able to get you one. mwagner@rinkerboats.com -
Cableguy Greg Member Posts: 5,052 ✭✭✭✭✭
Go Steelers!!! -
She is usually pretty quick.LuisMiranda said:
Do you know how long it usualy take to get an answer from Mallory? thksCableguy Greg said:Send an email to Mallory Wagner with your HIN. She should be able to get you one. mwagner@rinkerboats.com
Under the U.S. Coast Guard regs, a capacity plate is only required for boats less than 20 feet powered with an inboard, outboard, or stern drive engine manufactured after November 1, 1972, and must display a capacity plate defining the safe load limits. Since your boat is greater than 20 - no requirement for a capacity plate.
Now, for a "certification" plate, don't know what Rinker was doing in 1995, but NMMA/ABYC certification is voluntary. So you might not have one. If you do, it's usually in the helm area.
Just sayin' not legally required (federally) in @LuisMiranda's situation.
If yes, then you can have a plate made. There are numerous on-line sources. Just beware you must supply accurate information. There are also on-line resources to tell you how to calculate the capacity of your specific boat to print out a proper plate.
Here is a place that makes plates (decals)...
https://www.replacementdecals.com/store/c/119-Create-Your-Own-Capacity-Decals.aspx
As to the validity of whether you can have a homemade capacity plate, please refer to this from the US Coast Guard Auxiliary...
http://help.cgaux.org/index.php?/Knowledgebase/Article/View/363/6/capacity-plate-requirement-on-boats
