Re-bedding through hulls
Stodge
Member Posts: 2,738 ✭✭✭✭
I'm considering re-bedding my depth sender, retired sonar sender, genny inlet, head inlet and A/C inlet. Water has been sneaking in from somewhere since I've owned the boat, likely longer. The bellows are getting replaced this Spring. Just thought it might not hurt to cover all the bases.
Question: assuming they inlets/senders were put in correctly with 5200 What is the likelihood that they would leak and how much of a PIA am I looking at?
do it right
you Will have to remove all thru hulls but if properly installed you will destroy the inserts and pucks in the process.
my old Rinker had two ducers
one was still in use and other was absolete
long story short my compression nuts were loose and leaking.
i was able to tighten nuts against washers from
the inside of the boat
that stopped the leaks
but once again to do it right they have to be removed and resealed
same goes for the gen pickup.
i would take a shop vac and dry everything
wipe it all
down and watch for water intrusion or wet spots
sit on your lawn chair drinking a cool ice tea and wait lol
new and old rinker vent locations and design was horrible but so was my old dancer
