Bravo 3 moisture, loose drain screw!
Draining both drives today so that service can come and pressure/vacuum test them. I ordered the test pro actively, lube monitors were clean and didn’t drop. Port drained nice and blue, perfect, no concerns. Starboard definitely has moisture in it. It’s barely 40 in here so it’s a little thick. Here is the kicker though, the top air/drain screw plug  on the drive was loose. Zero effort to back it out, in fact with little effort I could screw it in 1/8 turn. I distinctly remember torquing on these screws in the spring so I’m baffled as to how it was loose. New high perform lube and new blue drain screw washers in the spring.
Given the loose screw, if the vacuum/pressure test comes back good I’m thinking i am good? Thoughts? Bottom screw had almost no metal shavings, just the normal trace amount, no concern.
  • aero3113aero3113 Member Posts: 9,865 ✭✭✭✭✭
    If it pressure checks good, maybe flush it good some how then refill.
    Yea I like the idea of buying all new screws, will look in to that. Agree on flushing, what do I use to flush? More lower oil? Hope to have the testing done this week.
    Mineral spirits to flush out.
    Thanks. Looking forward to test results this week, hoping that a flush and new screws are all that’s needed. I’d do all 4 screws.
    I change my screws and washers every other year. Cheap insurance.
    Never even thought about the screws, good to know
    Make sure you change the gasket. It sometimes gets overlooked.
    Thanks Greg, I changed the gaskets last spring but this spring I’ll do new screws and gaskets. Just hung up with marina to let them know about the water in the drive and the loose screw, they hope to test this week. Will update!
    I replace the gaskets every year but have never replaced the screws
    Gaskets every year
    screws only if there is a need. Drain screws get chewed up over time
    zaverin1 said:
    Gaskets every year
    Zav, I know the heads of the screws get chewed but do the threads? Making them less likely to hold tight?
    Look at it this way.
    yes everything gets damaged and worn out over time.
    i would also inspect the condition of the threads inside the drives.
    But in reality it’s very uncommon for stretches or blown threads.
  • raybo3raybo3 Administrator Posts: 5,615 admin
    Try putting a torque stripe on them. Then when the boat comes out of the water you will know if they are getting lose..........
    Good ideas, thought about a thread sealer but not sure that there is something that will take the heat of the drives and the lube. Don’t see anything reccomended
    I had problems with one of my drain plugs when I first bought my current boat.  The head on it got stripped and it wouldn't come off.  I bought a cheap harbor freight hammer driver.  I now use it every year and never have a problem with it stripping.
    https://www.harborfreight.com/impact-screwdriver-set-with-case-37530.html
    Note that I do mine while on a floating raft with boat on the lift.  This does make it a bit more difficult to get a firm stance while using a regular screwdriver to remove the plug.  (for those environmentalists, no, I do not let any oil go in the water.  I can actually do both drives at the same time now)
    Update: Vacuum & Pressure tests came back good. The drive with moisture held pressure for over 4 hours, they left the good drive overnight. All good. So I think that I am ok.
    I plan to flush the drive that had moisture with a quart of new LU oil. I plan to clean out the lube monitor, and then pour a quart of lube in the lube monitor and let it flow right out the bottom of the drive. This should flush out any remaining moisture. Then re fill both drives. Already ordered 4 new merc oem plug screws and gaskets for both drives, $30 delivered, not bad! Thanks!
    Sounds good you are getting closer to spring I mean launch
  • J3ffJ3ff Member Posts: 4,232 ✭✭✭✭✭
    Hey there, where'd you get them for that price? I also have found moisture in the drive and ended up with a completely empty lube resivour end of season last season. Figure I'll ask them to pressure test mine as well.. and then put some new screws in this year..
    Hey Jeff here ya go:
    https://www.ebay.com/itm/Mercury-Marine-Mercruiser-New-OEM-Magnetic-Gear-Case-Drain-Screw-22-8M0058389/401021962357?pageci=861a251b-f6e9-48d7-a13b-f125f70d216c&epid=1237712985
    Amazon had the sierra for the same price for 4 delivered and I’m fine with Sierra but figured I’d go with oem for the same price
    As we move into spring start up many places have sent discount e-mails. this company i have purchased from before with great prices and results. They are offering a 5% discount at this time. On there parts. You may want to hang onto the link for the future.
    https://www.dbelectrical.com/tilttrim_marine_discount/?utm_source=DBElectrical.com+Subscribers-MC&utm_campaign=677d307ec3-EMAIL_CAMPAIGN_2019_03_01_05_23&utm_medium=email&utm_term=0_71e4da393d-677d307ec3-69143971&mc_cid=677d307ec3&mc_eid=4bd276fad0
    Thanks to both of you - hmm, so the screws are the same for top and bottom of the drive
  • rasburyrasbury Member Posts: 8,967 ✭✭✭✭✭
    Yes they are Jeff..
    Made it back to the boat this weekend. Plan was to dump a quart of new lube in to the lube monitor and have it drain back through the drive and out the bottom to flush any remaining moisture. But, it wouldn't drain. No good reason why other than I assume a clog. Between the sludge, pressure test, and moisture who knows.
    Removing the lube monitor to clean was shockingly easy. Remove the strap, and then pull the hose from the barb. The wires pull out of small connections easily. Took home and thoroughly cleaned with mineral spirits, was surprised about how crappy it was down there. Spirits now flow smoothly out the bottom of them. I was able to blow air cleanly from the end of the monitor hose down through the drive so I think I got whatever was stopping the lube from draining. Ended up pumping a quart in to the top vent hole on the drive and letting it flow back out the bottom to flush, all clear, ready to fill Saturday.
    Should I use a little dielectric grease when reconnecting the wires?
    No need unless you see corrosion
    those tanks should be cleaned once every two seasons
    Liberty, I think you will be fine just reconnecting.  I've connected/reconnected a couple times there.  I remove mine each fall and clean it out.  Doing it yearly makes it a simple task, not much gunk in a year.
    Thanks guys, definitely will be adding this to the maintenance schedule. I thought I was getting most of the gunk with a screw driver and paper towel but I certainly was not.
    I replaced mine after a "failed" cleaning...I thought the fitting on the bottom unscrewed...well it does not...
    edited March 2019
    Yea I thought the same, I twisted the large nut about 1/4 turn and realized it does not un thread and put it back. I don’t think I jeoprosized the seal, mineral spirits didn’t drip. How far did you go Ras?
  • LaReaLaRea Member, Moderator Posts: 8,072 mod
    @Dream_Inn how do you clean it?
