Winterization Question Kinda
Hamdog
Member Posts: 247 ✭✭
Hey Gang,
I had my 2005 342 pulled from the water this spring for new anodes and to service the outdrives. After they put it back in the water, they changed the oil and filters in both engines and the generator as well as winterized the fresh water system and the A/C and toilet. When I received my bill, there was the usual list of what needed to be done as well as checkmarks beside each item that was done. I had told them to only winterize the generator....meaning don't change the plugs or impeller. So it said "Winterize Generator Only." There was no mention of winterizing the engines which got me worried. I called and asked and they said "Well, they better have winterized the engines or we will buy and install two new ones for you in the spring". I was assured that the engines were winterized but felt that the "technician" was never asked. Hence my question. There is a list of materials on my invoice. What materials can be expected to see on the materials list if the winterization actually happened? Just antifreeze I'm guessing.......how much for two engines and a generator? Any advise would be appreciated.
Thanks, Hamdog
tkrfxr,
They only used 8 gallons for everything l so I'm pretty sure based on your experience that they did not winterize the engines. I am going to talk to them again on Monday. Thanks for your response!!
Hamdog
