Mid Ship Leak
rasbury
Member Posts: 8,781 ✭✭✭✭✭
I thought I had this nailed but after a hard rain when I got home last night to work on my trim tab I checked the mid ship berth area and it was wet....bummer. I thought I posted this early this am but I don't see it...so if it is a duplicate, sorry!
Here is where I am at:
Since I have had the boat this leak has been there. The mattress in the starboard corner had gotten wet...the material had gone bad and I pulled the mattress out. It has not been a bad leak, more of an annoyance and I have certainly had bigger fish to fry for those that are on the forum regularly.
So here is what I did to start:
The "ceiling" if the mid ship berth is in two pieces...one large one that goes the width and length of it and then one other piece that is maybe a foot wide that runs the width. When I pulled them down, the large piece had obviously been getting wet for some time. There was mold on it and also the thin paneling/plywood was coming apart. The other piece to my surprise really was ok- it may have gotten a little wet as there was some discoloration but was not bad and do not intend to replace anything of that piece.
Now then, the way this is put together, you have other vinyl covered areas that run into the mid ship- you know around the entrance to this area. The edges are tucked up under the ceiling panels. I expected as I peeled some of that back to see water damage- It was completely dry around this panel. I had even removed and re sealed the window that is in the mid ship area as well- no evidence of water leaking...inspecting for either discoloration or mold. Right under the helm seat not quite in the center of this panel but a little forward was where the water was dripping from.
Looking at where else it might be coming from: It would not be from the door or the door track leaking in or under at it is lower than the "ceiling' of the mid ship berth. The only thing I could see that would be level with that "ceiling" was the following. The gray helm piece of fiberglass meets the floor of the deck or the other side of the "ceiling". Where they meet there is a caulk. When I looked in the inspection plate, it's kind of out but there is a "V" right there where they meet that looks like it would be a trough to collect water. I looked at the seal between the two and it seemed like it needed to be redone. Also, when the boat sits on the street pointing in the legal direction, the pitch of the road forces water to just sit there. It would disappear. So, I got some clear and resealed that. After some cleaning with the hose on the deck and watching down below I did not see any leaking so thought I had it until last night.
When I get down and look at where it is dripping, there are two holes right there where screws for the sealing went and it looks to me like it is coming out of those holes and not running there from somewhere along the sealing, hitting a low point to collect and drip. It looks like it is coming out of those holes...like it is in the deck itself and coming out of the holes.
When the helm seat is constructed, is it all a mold for the seat base and the upper deck half? Could I have some separation there I'm not seeing where water is getting in? I guess I need to stick something up in that hole and make sure it does not go through to up under that helm seat somewhere...like to long of screws were used. Would that not be sweet to resolve like that and will look at the screws.......I don't see where it could say run down from a window mounting screw and get to where it is dripping from....I just don't see there being that path to run to...if it were in the main cabin yes but it would have to go down and then back up to get to that ceiling....I wish I new better how the hull was built and put together....maybe I'll take that apart next!
I'd pick up a cheap endoscope off Amazon and use that to poke around the various places near there. Could be a simple fix.
Good luck man! I'll be heading that way in the near future - I need a celebratory vacation for a few days of R&R. I usually head to Florida to play.
So, I pulled the piece where the crappy cooler used to go. To recap, I pulled the two pannels off the ceiling of the mid ship. The front one/ towards the bow was "ok" and really did not look like it had been getting wet. The next one, big one, towards the stern had been getting very wet, was molddy and the wood was falling apart. With the mooring cover on, no leak. With the fact that it was leaking through the ceiling of the midship and not just running down it I was convinced it was something above the ceiling. When I opened up under the sink where the cooler is, there is a large pan under there which will catch water if it comes through the trash lid. Not really sure why it is there..it runs from under the sink to up under the helm seat - EXCEPT- know where that storage area is under the helm? Right underneath that, that pan jogs around it. So, when I soaked that bare area underneath it and went back down, there are two holes in the ceiling which are two of the screw holes that mount the ceiling, water is dripping. I notice when I soaked the helm seat area, water is coming through and dripping to that bare area. So, found it, just not sure how to fix it! I am tempted to drill out one of those holes and see what is above it.....
