Crazy....anchor line too thick for my cleats!
luvinlife
Member Posts: 501 ✭✭✭
Here's an odd one. The anchor line on my 2006 Fiesta Vee 270 is too thick to fit on either of my bow cleats AND the cleat in the windlass anchor locker. I assume it's the stock line and chain, but I can't believe Rinker would build the boat with this setup. My options are to add larger cleats or a smaller diameter anchor line. I am not sure what thickness the line is but I will measure it once the shrink wrap comes off. One of my spring projects before I splash is to rectify this issue one way or another.
Although, if it's windy and other boats are coming, I probably should tie a Prusik. By Murphy's Law, my boat will always swing wildly just as another boat approaches to raft up. A Prusik would be a little safer.
Definitely give the prusik knot a try! I'm hooked on it and use it quite often now. I have a line dedicated just for it.
The old arrangement was a cable and one of the end loops gave way.
Just curious.
It's all about increasing the horizontal distance between the rode attachment point and the boat's center of mass. If the distance is longer, the anchor rode applies more torque to prevent the boat from swinging.
With a bridle, here's what happens: When the bow swings to port, it slacks the stbd side of the bridle. When the bow swings to stbd, it slacks the port side. Either way, a bridle gives you a longer torque arm, higher torque and therefore less swing.
I know EXACTLY what your problem is........................You need a bigger boat!!
& yes, the "torque" or what I'd rather say moment of inertia, revolves a bit further back from the bow, causing less movement/swinging. It is definitely noticeably better.
