EVC The "NEUTRAL" Button
Ok folks, my new Rinker 270 FV w Volvo D4 diesel is awesome, however I have noticed that the throttle is quite notchy around the centre...its a 2005 model with something called "EVC" does this mean it has a 'slow mode' built into its throttle profile?......basically the idle speed seems to high for mooring up ....appreciate some advice before I line the pockets of the local engineer!!
If it is an engine setting speed issue - I’d take a look at the manual avail for the EVC system
Perhaps you have a similar set-up???
I may try using the N button on the EVC as this may be a simpler solution, thanks for your help, all the best
We are generally very pleased with the D4 engine -- but -- regular, routine servicing is even more important than on other engines and we now know that ours suffered badly before we had it from excess water getting into the engine bay -- so keep your bilges dry!!!!!
Nick.
Specially when docking.
stern drives with electronic shift are amazing and act like inboards.
