transom mount question
I'm on my third engine with this 05 212 captiva... this one is a mercruiser factory built engine, in the 357 variety and, well, i'm toning it down some as this engine is actually less powerful than the 304/314 i pulled.
at any rate i'm having a hard time aligning the engine to the outdrive. I don't recall EVER having such an issue in the past.
my question, and i've asked it before and didn't get a definitive response. Does the rear engine mounts rely on the coupler housing (akin to bell housing) or the transom mount to determine the correct fastener kit, or is it a combo of both?
This engine has 'deeper' (for lack of better word) bosses than the last, and the isolator bushings are pressed into the ears. obviously, the transom plate hasn't changed or i would have offered that. the problem with the 'half valve spring' type mounts is the bolt is just plain too short, and the problem with the laminated fabric washer/bushing kind is the difficulty aligning...
First engine stock. Second engine was ragged edge and didnt expect it to last, and the window popped in the skirt via escaping rid confirmed that... It was fun while it lasted, though . this one is mercruiser factory built 357. It'll be fine performance wise, as last engine found the limits for the hull and drive... This one is a bit under it in terms of tq and hp, but enters the curve much sooner.. Will be great for recreational boat/engine combo.
I've used all kinds of tricks to get those bolts through the washers/short spring.. Including super glue lol.. I even fabricated a tool to cradle the nut that can easily be held while turning the bolt by hand but on a 6"+4" extension.
Im all but certain ive got wrong kit. Looks like there are at least three kinds... Problem os I dont know if its determined by coupler/flywheel cover or the transom plate. ............. Or both.
the other two engines weren't a problem at all. the front mount bases are the same ones holding the last engine, so even they are not a problem...
i'm just gonna make it happen... but it shouldn't be as difficult as it is. something is amiss.
