Cellular antenna
taylor1taylor1 Member Posts: 46 ✭✭
We cruise the Mississippi north of St Louis, the cellular coverage is very spotty, I have read about many different ways to boost or amplify the signal, does anyone have a recommendation for a 08 400 EC setup??
Thank guys👍
    I've used "portable" cell boosters in the past.  These consisted of a small mag mount antenna that could be set up on the arch and a powered handset holder.  Might look in that direction and see if there is anything like that on the market before going for a permanent solution.
    It’s really all about what service is available in a given area and if roaming is covered
    I have a hotspot with an external magnetic antenna that I use, get's an ok signal and rebroadcasts as Wi-Fi. The biggest thing is research - figure out your service provider vs the service available in the area - if there's signal you can get an antenna positioned to receive it - that's a guarantee. Might check nearby for wifi - a 2.4ghz yagi could give you a decent internet connection from a mile or more off.
  • IanIan Member Posts: 2,932 ✭✭✭✭
    edited April 2019
    Don’t phone providers offer some boosters where their signal is low? Mainly for those in houses where cell signal is low and I think drops to a local Wi-Fi but that may be an option too. They want you to use data for revenue ....
  • taylor1taylor1 Member Posts: 46 ✭✭
    The providers vary and the signal can be nonexistent as you travel between St Louis and Quincy on the Mississippi. Considering this system, decent reviews online.
    weBoost Drive 4G-X 470510 Cell Phone Signal Booster, Marine Bundle, Cell Signal Booster Kit for Boat & Marine Applications, Boosts 4G/LTE/3G Signals – Maximum Cell Signal Boost Allowed by FCC https://www.amazon.com/dp/B07P13KG13/ref=cm_sw_r_cp_api_i_tlPOCb8Y8AR8Z
    For that kind of money I'd stay disconnected.
    In that case a booster is of little value if it has nothing to boost. I agree with @Stodge
