Trim Pump Reservoir Leak
RinkerRookieRinkerRookie Member Posts: 38 ✭✭
Last fall I noticed a little trim fluid leak in the bilge.  The cap seemed to be stripped so I installed a new one.  I just pulled her out of storage and it has leaked more.  It appears to be leaking from where the pump motor meets the reservoir.  I was thinking of just replacing the o-ring (#15).  Just thought I'd ask in case these pumps are notoriously faulty and I should just replace the whole unit. 2010 246 BR w/approx 350 hours.  Thoughts?
Fin and Tonic (w/Lime)...
  • rasburyrasbury Member Posts: 8,782 ✭✭✭✭✭
    Well, as soon as you see a price to "replace the whole thing" I'm sure you will be looking at that seal again....I'd order the seal and take it apart and go from there....either the seal is bad or perhaps something struck the tank itself and has a crack in it...can't imagine what the whole assy would cost....
  • IanIan Member Posts: 2,998 ✭✭✭✭
    edited April 2019
    I had a motor go on me a few years ago and found one on eBay. It was pretty easy to swap it with no need to change the o-ring. I’d be sure it is the o-ring, is the motor/pump assembly screwed down fully?
    Post edited by Ian on
    His motor seems fine, just a leak...I don't know about him but I can't afford to replace something I can fix- I'd have a new boat by now!
  • RinkerRookieRinkerRookie Member Posts: 38 ✭✭
    After further review, I think the leak may be coming from the quick connects (#5).  These also have o-rings.  I'm going to order both sets of o-rings and replace.  Hopefully that's it.  The only reason I asked about replacing the whole thing is because I wondered if they were notoriously bad units.  Thanks for your input.
    QDs are notorious (in general) for leaking.  Hopefully that is it!
    I"ve had three boats with merc power trim and never had a problem with any of them or leaking...
    same here.  (did you just jinx us?)
    With the issues Ras has had I am sure he did  :smirk:@RinkerRookie I still say check where the pump fits that it is screwed down right, maybe not necessarily the o-ring itself. I agree, no need to change motor if not needed, just that overall as a unit only my motor went, not the pump itself.
